dbbls
Aug 23, 2013Explorer
Are you sure the "inverter" is 55 amp. or the "Converter"? All trailers have a converter, converting 120 volts AC to 12 DC. You would have to order the "inverter" if you wanted it. It converts 12 volt DC to 120 volt AC. If your new trailer only has one air conditioner it is probably 30 amp.
44,056 PostsLatest Activity: May 04, 2014
