- DownTheAvenueExplorerIf this is a warranty issue, then a call to Airstream will give you guidance. Otherwise, unless it is body work or axle replacement, any RV technician could do the work with, most likely, off the shelf parts.
- Johno02ExplorerNot a recommendation, but there used to be a Camping World store and service on the south side of Chattanooga going toward Atlanta. Back before Marcus took over, they were a good pick. Now, haven't been there in may years.
- normal_daveExplorerYour nearest dealers are Huntsville, Atlanta, and Louisville, TN.
Don't know him, but here's a page for a local master certified RV tech. A quick glance at his page gives me the impression he knows his stuff, bet he speaks "Airstream".
G&G Mobile RV Repair
Edit: found the web page.
G-G RV repair
Give him a call, see if Airstream will use him if under warranty.
Good Luck! - gboppExplorerI'm not familiar with the area. Maybe you can call some campgrounds and ask about local mobile RV techs their campers have used?
Hopefully someone has a better response.
44,067 PostsLatest Activity: Jun 03, 2026
