dmullen wrote:
GrandpaKip wrote:
Don't really understand your first question. Do you want to hardwire the camper to shore power?
For the second question, that is where I would put it.
I am removing the shore power cable and replacing it with a Furrion power outlet. I am going to add the EMS at the same time.
I found a few pages about it on line. Yes, you could use romex from there to your ems and then from the ems to your panel. You dont want to use romex where it will be flexed over and over. Romex of the proper size for the amperage securely fastened will be fine.
