coolbreeze01 wrote:
I don't like the auto downshifting. So much smoother when I do it.
Works great, you should try it before criticizing.
Maybe driving a 5&4 with a Jake brake in the hills made me a better operator.
I am not going to tell you how to run your truck, but towing without tow/haul mode is asking for premature transmission failure. Contrary to most peoples beliefs, a buttery smooth shift is harder on a transmission than a firm one because the smooth shifts allow the clutches to slip causing heat and clutch wear. In tow/haul mode, the transmissions line pressure is increased which makes for a quicker firmer shift and reduces clutch slippage which means less heat. It also holds gears longer because a constant shifting transmission creates more heat. You can run your truck as you wish, but I just thought you should know if you don't.
