MFL
Mar 28, 2023Nomad II
plasticmaster wrote:
When towing on flat terrain and taking an exit off the interstate, I would prefer it not do the insane downshifting. In this situation, I've been turning off tow haul as I take the exit cause I have plenty of time to stop.
In my experience, the Ford T/H mode works great, while using as described above. I would question, if your trailer brakes are working properly, adjusted properly, to help slow to a level stop?
If you are pumping the truck pedal, it will continue to downshift, which should not be necessary on level ground, and the length of most exits.
Jerry
