MFL
Mar 29, 2023Nomad II
Grit dog wrote:MFL wrote:
On a steep downhill, with 10K pushing me, I prefer to not use t/h, and manually select gear I want to use. This works best for me, on long downhills, that also include lots of turns.
Jerry
Not sure I’ve seen a manual mode (+/- button) on any newer truck that will prevent further downshifting if the truck calls for it. Either slowing down below min speed for the top gear selected or in a grade braking scenario.
From the old 6 speed Fords that the OP has to new GM 10speeds.
They’re great at limiting up shifts to whatever top gear you want to maintain.
You are right, my 6R140 is not a six speed stick, and can/will do its own thinking when absolutely needed. It will hold me back on a lengthy downhill, in 3rd/4th. If rpm demanded an upshift, as in reaching redline, IDK? It's never come to that, as I just apply brakes as needed, but applying brakes does not downshift, when not using T/H.
Coming to a stop in manual mode, it will downshift on its own, but not as soon as when in drive mode. It will drop to 2nd when stopped, rather than 1st.
The OPs transmission, not the same, but should operate similar?
Jerry
44,070 PostsLatest Activity: Jul 20, 2026
