KD4UPL wrote:
You can brake with the engine on a diesel, just not nearly as well as a gas engine. That's why most diesels have exhaust brakes.
This is only true to a point! Diesels have a 17 to 1 compression, but engine speed is controlled by fuel, not available air as the air path is unrestricted.
that said if you are foot off the throttle, you are only getting enough fuel to turn the engine at about 850 rpm. The only way you see any, and I mean any engine braking from a diesel is to have it turning about 2,800 rpm with idle fuel. Some, but not as good as a gas engine.
Now put an exhaust brake on it and it is a far different story. I installed a turbo mounted Pacbrake PBXB, this has a plate with about a 3/4" to 1" hole in it, this hole is covered by another spring loaded plate. At high rpm it acts like a standard EB the pressure opens the 1" plate and it provides plenty of whoa. Then at lower rpm, the pressure can not overcome the spring pressure, and now there is a full plate closure still providing lots of whoa.
In a non panic situation I could loose the TV brakes (hydraulics) AND the trailer brakes and could bring the TV and 5er to a full stop on a flat, or even moderate down hill. The final stop would either be parking brake, or shutting off the engine.
Even on the steeps grades in the Oregon Coast range, I never need to touch my service brakes, this is with 19,000#+ GCVW.
I drive a manual, I might even pay the price of a de-tuned Cummins 6.7 just to still have a manual.
