colliehauler wrote:
If you have run Mobil one and changed every 5 to 6k I would be willing to bet your motor is quite clean. I bought a high mileage vehicle with a 5.4 with known narrow oil passages. My mechanic said you can do more harm flushing then going to benefit.
lifters are a little noisier now that it has 210,000 miles.
He most likely has a collapsed lifter...
Its not going to go away with just an oil change..
If engine flush of ATF dont work, then pull the valve cover, find collapsed lifter. Pull rocker for that lifter and spray cb blaster down push rod to lifter.
Reassemble and see if that works..
Otherwise you need to pull head to replace lifters...
https://www.youtube.com/watch?v=dQNAvoQ4-T8The previous vid I posted shows that process..
Its a GM thing... Fords also have their issues with thier cam phasers and such.
