Second_Chance
Aug 02, 2018Explorer II
Not nearly enough info on which to base an answer. Where did you get the DEF (jug or truck stop pump) and, if in a jug, what was the date on it? You're likely to get fresh DEF at a truck stop pump since they are very high-volume and truckers aren't going to put anything iffy into those expensive tractors. It's sometimes difficult to determine the "chain of custody" and storage conditions with DEF in a jug depending on where you bought it. Doing a quick search, I can't find any references to a "PTS" code relating to Ford PowerStrokes. You might ask the same question(s) over on the Ford Truck Enthusiasts Forum and see what you get.
Rob
Rob
44,055 PostsLatest Activity: Dec 23, 2025
