shasta24ExplorerMay 22, 2013engine modsHas anyone installed a comp cam into a suburban with any luck? My tv is a 95 , with 350 and 373 gears. Just could use some more power. It only has 66000 miles on it so its not worn out.Thanks
donn0128Explorer IIMay 22, 2013You basically asked the same questions in your first post. I assume you were not satisfied with the answers you got then?
Related ContentPotential engine overheatingNear engine overheating gauge95 suburban engine modsShow your mods!!Need Advice on E450 Engine Mod
