Has anyone installed a comp cam into a suburban with any luck? My tv is a 95 , with 350 and 373 gears. Just could use some more power. It only has 66000 miles on it so its not worn out.Thanks
4.10 gears will help a good deal in keeping the engine's RPM's in the max power band while towing at 60-65 MPH. With tall gears the engine is challenged especially with the older vehicles with 4-speed transmissions. With the GM 6-speed transmissions the first 4 gears are all underdrive and 5th and 6th are both overdrive gears.
