I wonder about a 400 small block Chevy crank in the 350...which would give you a 383 cube V8. Also an RV/tow truck cam ?
You can call different cam companies and their consultants can advise and this is something I would recommend.
Or check out some GM crate engines...not all are hot rod engines.
You have to be careful though....all this can add up and unless you can do the work yourself...it could be costly.
Maybe not cost effective.
I'm not an expert and many of the other guys offering advice aren't either. So wise to review different ideas with someone who has expertise.
