wannavolunteerFT wrote:
I had that happen to me back in November in my 2010 F150.. Mine shut off once, restarted and I assumed it might be trash in fuel line (I was stopping and starting and turning around on mountain roads). It stopped again about 5 minutes later so I called for help. I was miles from campground in NGA mountains and several hundred miles from home. I got a tow to local Dealer as I didn't want that happening with TT attached.
Turned out there was a service bulletin for some type wiring short between fuel pump and computer controls. Only took them a couple of hours to diagnose and repair (thank goodness). I was kinda bummed that my local dealer had not mentioned the service bulletin when I had the oil changed/basic service done just a week before.
Dealers generally will not inform you of a TSB. It is there for them as a reference to aid in repairing vehicles that have exhibited consistent or similar symptoms. So unless you go in and state you are having an issue they are not going to go searching for all the TSB's on your vehicle.
