jefffoxsr's avatar
jefffoxsr
Engine squeaking #$%#$%#
This is not a new problem. I have been trying to locate the squeaking problem for a while now. It's there one week and not the next. There is no correlation between weather temperature, humidity, season, etc. This truck only has 70,000 miles by the way.
Today I replaced the serpentine belt, the AC belt, the belt tensioner, and the alternator. The alternator was squeaking when I rotated the pulley by hand. The new alternator did not eliminate the squeak. The AC belt tensioner functions appropriately. I thoroughly cleaned the grease off the pulley surfaces.
I really need to get this fixed.
What else is there to check or do to eliminate the squeaking?
Thanks for your help guys.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    On my wife's old Caravan, I replaced a couple of the pulleys. These pulleys had bearings in them and would go bad.
  • Actually there is plenty of room without removing the radiator, just pull that top shroud and take off the fan and fan clutch.
  • Out west here, they come off pretty easily as long as you have enough room to work. I don't know if they come off easily in the rust belt. You might have to remove the radiator to have enough working space.
  • I have the goodyear gatorback. I removed the belt and started the truck. The squeak is still there. The harmonic balancer is not spinning straight. It is crooked. That must be the problem. If I get a puller does it come off easily? Could I just throw on a new one without doing anything extensive like removing the front cover?
  • Jeff, I chased this same problem for years and finally found the solution on one of the GM truck forums: Use only Goodyear GatorBack belts.
    I changed the belts and tensioners several times, and each time the squeak would go away for a while....but it always came back. About 2 years ago I changed all 3 tensioners and both belts and installed the Gatorback belts, and have been quiet as a mouse ever since!
    Something about the 8.1, lots of guys have the same problem
  • this video helped me with my "squeak" are you sure all the pulleys are lined up?
    https://www.youtube.com/watch?v=fPjmBQc2gGQ
  • Where is it located and how do I assess its integrity please? Thanks.
  • A separated harmonic balancer can cause this, and usually is only found after replacing everything else that moves under the hood.
