myredracer wrote:
The V10 6.8L was rated 362HP with 457 ft-lbs torque. The 6.0 V8 in the GMC is almost identical HP at 360 but the torque is 380 ft-lbs. Both trucks have a 4.10 rear end.
Am wondering if the torque difference is going to be noticeable and if performance will be down in the mountains?
100 ft-lbs less torque, HECK YES you are going to know ! Better start shopping for something with more power.
Torque curves do matter, but nothing is going to make up for that missing 100 ft-lbs. The Ford V10s get more torque at higher RPM so you do have to wind them up a bit.
