Lynnmor wrote:
4x4ord wrote:
Unless you have an infinitely variable transmission an engine needs to deliver power to the transmission over a range of rpm. The power the engine is capable of making over that rpm range is described by the HP and torque specifications. Torque at rpm is power. If two engines make identical peak horsepower at 4800 rpm but have different peak torque numbers, the engine with the higher torque is the more powerful engine and will pull better.
Nope, identical power. Yes, there can be minor differences depending on the torque curve and gearing, but all this is hypothetical.
The engines I describe are hypothetical but the principle is that higher torque engines are better in tow vehicles when compared to similar powered lower torque engines especially when the rear axle ratio is left the same.... the lower revving engine will make better use of its transmission.
