myredracer wrote:
Lynnmor wrote:
Maximum horsepower is at 5400 RPM, how close to that were you running when you couldn't hold the desired speed?
Around 4K is about all I can remember.  It was kicking into a lower gear and up to around 5K at times but that was on inclines that weren't as steep.  Like the F250, I thought if I slowed down on steeper hills and pushed the peddle to the floor it would kick into a lower gear but it wouldn't and I was stuck with lower rpms and less power.
Not sure what sensor(s) makes the tranny shift?  Air flow or... ??  Maybe a sensor needs cleaning or an adjustment is needed on something?
Do you recall what rpm you were spinning in the V10? I wonder if the V10 happened to be geared perfect for the Coq and the GM 6 spd is stuck at a less than ideal rpm (4k). Less torque makes it more crucial to be perfectly geared.
Also, is this only during the steeper hill (8% one at the snowshed), or at the 6% hills as well?
