Lynnmor wrote:
myredracer wrote:
Not sure what sensor(s) makes the tranny shift? Air flow or... ?? Maybe a sensor needs cleaning or an adjustment is needed on something?
Possibly the throttle position sensor, an easy fix. TPS
That sounds like a good possibility. Part is inexpensive and not hard to install. According to google, it sounds like reprogramming might be required? Could mean a trip to a shop to get that done?
I need to replace a burned out turn signal bulb at the front. Access to the bulb means pulling the bumper away, the inner wheel well liner away and removing a plastic cover above the rad. OMG... Easier to get at the TPS.
