kw_00
Apr 15, 2018Explorer
KD4UPL wrote:
Given that you are apparently open to GM products why not consider getting a GM 2500 truck? Then you wouldn't have to worry about 2 different diesels to avoid and gas engines with spark plug issues. The 8.1L GM big block and the 6.0 GM small block gas motors have very few (if any) chronic problems. The Duramax diesel has been excellent since the 2004.5 LLY introduction got away from the problematic injectors of the early Duramax.
I second this for sure from experience, if you don't go for the ford 6.7 then consider the GM side.
