Maxpax's avatar
Maxpax
Entry Door Seal
Hi All:
I have a 1990 Prowler 26B. The entry door needs to have a new seal around the perimeter as it has shrunk about 1-1/2" on all sides leaving about 3/4" each way from the corners that do not seal.
The seal appears to be about 3/8" round and hollow, made from vynal with a small t shaped protrusion that looks like this ( O-| ) but without the spaces between segments. It slides into a grove in the frame of the door itself. The upper and lower door trim has to be removed inorder to slide this seal into place on all 4 trim pieces.
Has anyone replaced there seals.
Thanks
1 Reply
  • I am not familiar with you TT but these may help in locating the right seals.
    www.pellandent.com
    www.uni-grip.com
    www.rvsurplus.net
    Each of them has a very large selection of seals. Good luck.
