TECMike wrote:
My 2010 trailer came with the EquaFlex suspension with greaseable wetbolts and bronze bushings in the units. I ordered new EquaFlex components for both sides of the trailer today and they come with a composite or perhaps nylon bushings. Perhaps they are "NeverFail" bushings from Lippert..not sure.
Should I remove the old bronze bushings and wet bolts from my old units and reinstall them in the new units, or use the supplied composite/nylon bushings. If so, should I use the wet bolts or buy traditional spring/shackle bolts to use with the new composite/nylon looking bushings?
Thanks in advance for your help.
IIRC the NeverFail bushings are a dark plastic, the usual nylons are white.
If the bronze bushings and wet bolts are not worn, I would reuse them and save the new bushings. And check the shackles too.
