TECMike's avatar
TECMike
EquaFlex Bushings
My 2010 trailer came with the EquaFlex suspension with greaseable wetbolts and bronze bushings in the units. I ordered new EquaFlex components for both sides of the trailer today and they come with a composite or perhaps nylon bushings. Perhaps they are "NeverFail" bushings from Lippert..not sure.
Should I remove the old bronze bushings and wet bolts from my old units and reinstall them in the new units, or use the supplied composite/nylon bushings. If so, should I use the wet bolts or buy traditional spring/shackle bolts to use with the new composite/nylon looking bushings?
Thanks in advance for your help.
  • I have had the bronze bushings fail. I am now using the Never Fail ones. I have not seen a single report of the Never Fails... Failing.
    One thing is certain. You cannot use the greaseable bolts with the NeverFails. It says so in the instructions.
    I think the previous posters are thinking of the "stock"nylon bushings. The Never Fails are different, and relatively new to the market.
  • Keep the bronze bushings and grease blessed bolts.
    x 3
    X2! There are some people that have had the "Never Fail" bushings....fail.
    B.O.
