AH64ID
Apr 18, 2015Explorer
Huntindog wrote:AH64ID wrote:Mine ARE different. My 12K bars could be installed upside down based on the sticker.(because the cutout was centered) My 14Ks cannot... The cutout is offset, so they will only insert into the head one way, and that also prevents 12K bars from being used in the 14K head.
Since progress mfg labels the bars you will need to call them to identify the head.Huntindog wrote:
I have had a 12K and now a 14K. They use the same sized bars (probably a different strength though) But they will NOT interchange. The half moon cutout on the 14K bars is offset, and the 12K bars is centered.
I beieve the smaller versions use a smaller bar.
Per my call to Progress mfg last fall, and having my dads 14K bars and my 12K bars in hand at the time, there is zero difference in the bars(besides the sticker). The instructions do say there is a difference in the cutout, but there isn't.... At least not on their kits made in the last 8-10 years.
The heads were visibly different, but bar interchange was possible. The bars are identical, and the only difference is what sticker they get.
The difference between a 14K and 12K setup is the head on the 14K unit is a little stronger.
I bought the 14K new when I got my present TT new, back in 2009.
Interesting, my dads 14K bars can go in on either side, upside down, or on my 12K.
Based on the info I got from Progress Mfg it sounds like your kit may have been on the shelf for quite a while.
Do your L brackets attach with 1 pin bolt, or on two studs?
