JJensen79
Mar 27, 2014Explorer
You should be good with the standard shank. The receiver actually sits kind of high on the Expy so you might be at the lower holes of the shank. Once you get it home double check all of bolts on brackets mounted to the a frame. Some of mine were loose after the ride home. Also double check to make sure they mount the brackets in the right locations. Mine were installed to close to coupler.
By the way, good looking TT you got.
