Hondavalk wrote:
Looks like a Bingo to me. From the manual:
"In some cases the friction on the L-brackets can generate noise. Lubricating this joint is not recommended."
L bracket sway jackets are the company's response to excessive noise, particularly during low speed turns, and as such acts as a "lubricant". The point is rather moot anyway as the company itself says on it's own website -
"Use of the Sway Bracket Jackets does slightly reduce the amount of friction sway control provided by the L-bracket assemblies. However, this reduction is minimal, and in most applications barely noticeable because the majority of the Original Equalizer Hitch’s integrated sway control comes from the rotational friction surfaces of the spring arm sockets in the hitch head. This sway control is not affected at all by the use of the Sway Bracket Jackets. The L-brackets will still provide a certain measure of sway dampening friction."
In other words lubricating the L brackets will have little effect on reducing sway control. I myself for years used a dry film spray lubricant on my own Equal-i-zer, sockets
and L brackets, with great results - significant reduction noise, no noticeable reduction of sway control because most of it occurs at the head sockets. :B
