leftybj's avatar
leftybj
Equal-i-zer wdh question
I have a half ton truck and 28 foot trailer. I use an equal-I-zer hitch and am very satisfied. I am thinking of buying a larger truck. If I buy a truck that does not squat down when I hook up the trailer, I won't need tension to level everything out. Without tension on the spring bars I loose sway control. Anybody have experience with this?
  • leftybj wrote:
    ---If I buy a truck that does not squat down when I hook up the trailer, I won't need tension to level everything out.---
    Even if you had zero rear-end squat, the TT still will cause load (probably around 400-500#) to be removed from the front axle.
    Depending on which truck you get, the manufacturer might specify restoring 50-100% of that load.
    If you get a 2012+ GMC/Chevrolet, they might say you don't need a WDH.
    The Equal-I-zer's ability to resist sway is proportional to the amount of load transfer (bar load).
    Without load on the spring bars, you will lose sway control.
    Ron
  • Also need WD to meet your hitch receiver ratings.
    What is your trailer's loaded tongue weight?
  • I went from a 150 to a 350. The front fenders went up one inch so I adjusted to bring it down a half inch, sway works great. Also the new trucks have some built in sway as well.
  • You will still need a WD hitch, even a larger truck will squat. You will still have sway control with a larger truck.
