I have a equal-I-zer I am istalling on my tt the only problem I am having the directions read try to keep the arms parallel with the trailer frame this will help reduce the noise the hitch makes when ...
The noise does not come from non parallel arms. That is an entirely different issue, but the arms should be parallel with the A frame under tension. The Equalizer hitch is noisy during tight turns especially in campgrounds at night when all is quiet and they pop, bang, grind, grunt, and creak. After a while the embarassment is over and you will realize that it all comes with the experience. Other hitches are much quieter.
