mimosa
Nov 29, 2013Explorer
equal-i-zer
I have a equal-I-zer I am istalling on my tt the only problem I am having the directions read try to keep the arms parallel with the trailer frame this will help reduce the noise the hitch makes when ...
jmtandem wrote:
The noise does not come from non parallel arms. That is an entirely different issue, but the arms should be parallel with the A frame under tension. The Equalizer hitch is noisy during tight turns especially in campgrounds at night when all is quiet and they pop, bang, grind, grunt, and creak. After a while the embarassment is over and you will realize that it all comes with the experience. Other hitches are much quieter.
