I have a equal-I-zer I am istalling on my tt the only problem I am having the directions read try to keep the arms parallel with the trailer frame this will help reduce the noise the hitch makes when ...
Not to start any arguments,but....From their website: ATTENTION: Utilizing lubrication on the Equal-i-zer L-Bracket, in the form of the Sway Bracket Jacket or any grease type lubricant, may lessen or decrease your sway control by a small degree. Steel on steel is the highest level of friction, steel on lubricated steel second, and steel on plastic third (but also the cleanest). The hitch head can be lubricated, as per the instructions, with no detriment to sway control.
