I have a equal-I-zer I am istalling on my tt the only problem I am having the directions read try to keep the arms parallel with the trailer frame this will help reduce the noise the hitch makes when ...
The majority of the sway control is from the hitch head. I don't lube the L bracket surface, but even if I did it wouldn't 't make much difference in the performance of the hitch. Hence the term 'small degree'.
