Ron3rd
Sep 29, 2014Explorer III
You're good on the weight distribution IMO, but what concerns me is you said the bars are not parallel. They should be parallel to the surface they ride on on the L-Brackets on the frame so they take maximum advantage of the friction provided there. If they are at a little bit of an angle, you're probably OK if you can't get them more parallel by moving the hitch head or the L-Brackets as most of the friction control is in the hitch head.
44,070 PostsLatest Activity: Sep 18, 2026
