SoundGuy
May 05, 2015Explorer
Dave Pete wrote:
Finally got it all set, except on occasion the hitch made loud, ugly noises while turning and at first I could seem to control it with more grease (I use white lithium) on the pressure surfaces (the noise was coming from just one side at the hitch platform. The socket I think it's called.
Progress Mfg would argue that noise you're hearing is normal - Page 26 of the Equal-i-zer owner's manual. You can mitigate that noise somewhat by using Equal-i-zer's own brand of lubricant (sparingly) ... with my own EQ I used a dry film lubricant called Slip Plate that is sold by Tractor Supply. Regardless, if your Equal-i-zer is properly sized for the task at hand and properly adjusted it will be noisy ... just the nature of the beast.
44,070 PostsLatest Activity: Aug 07, 2026
