aarond76's avatar
aarond76
Equalizer vs Dual Cam
I am currently pulling a roughly 9,000 lb 34' camper with a Reese Round bar WDH and friction sway control. My bars are rated at 1,000 lbs, I am sure tongue weight is substantially more but they seem to ride fine.
I want to get rid of the friction sway and go to either a Dual Cam or Equalizer set-up. If I stay with the 1,000 lb bars I can add the Dual Cam for around $200 so that is the cheapest option. However if I go to heavier rated bars I'm basically buying everything new and the cost is comparable between equalizer and a complete new dual cam set-up.
I had a 600/6000 lb Equalizer on a hybrid before and liked the set-up. The Equalizers were very popular with the hybrid people. It seems like the heavier campers tend to go with Dual Cam more often. Is one system better then the other when towing heavy? I want the nicest set-up I can get without going the $$$$ route of Propride or Hensley.
On the Reese hitches is there any performance difference between round bar and trunion bar? I see a fair amount of the trunnion bar 1,200 lb hitches complete with Dual Cam on Cragslist. The ball mount on our camper is attached to the top of the frame, I assume that limits me to round bar and the trunnion hitches are made for campers that have the ball mount on the bottom of the frame?
Alot of people say to add a 2nd friction sway bar with this long of camper. The only way to do that on a Reese hitch is to have someone weld another plate on the left side of the hitch head. By the time you do all that you might as well pay a little more for the Dual Cam so that is not really a consideration.
Thanks.
