Fireman02 wrote:
Equal-I-zer. We are pretty nose heavy as far as everything is loaded either in the bed of my truck or the front of the trailer. I didn't fill my fresh water tank this time which would help put a little more weight over the front of the trailer.
If you're running the Equalizer brand hitch and getting "a lot of sway" something is not set up right with your hitch IMHO.
Every time I've towed with it, save 1 time, it's performed very well, and that's many many trips.
The one time it performed poorly was when I actually forgot to torque the sway arm bolts so I basically had no sway control and only the weight distribution.
