Fireman02 wrote:
I'm still waiting to hear back from equal-i-zer, but i looked through their set up directions and went to take some measurements. My L-brackets were about 29 1/2"' back, and the driver side L-bracket wasn't completely vertical from the ground. I re-adjusted the brackets to the recommended 32". i'm not sure if this will make a difference. Our next trip i 6-7 hour drive, so i hope to have it dialed in by then.
The farther back you have the L-Brackets, the better the sway control. 32" is fine.
