rirish1's avatar
rirish1
Equalizer WD problems due to new tow vehicle
I recently upgraded my TV to a 3/4 ton chevy 4x4. I tow a 29ft TT with a max weight of 7K lbs. The TV is a perfect fit but it sits much higher off the ground then my old 1/2 ton. I have the WDH on the lowest possible holes yet the trailer still sits about 2" nose up. Another annoying problem is the tailgate won't open now (it hits the power jack). I was hoping to purchase a new shank to solve both problems but can't seem to find anything commercially. I figured I might as well go to a 2 1/2 inch shank since the truck has a 2 1/2 inch receiver. I only need a couple more inches of length to fix the tailgate and need a couple more inches of drop. Does anyone have any suggestions or should I just try to get something manufactured locally.
  • 2" high is a lot. The Equalizer I have has quite a bit of drop. One of the most I have seen. If you cannot get enough drop, you may be able to raise the TT to compensate. A combination of an axle flip, larger tires, and or lift blocks may be used. I have used all three methods or combinations as necessary to lift all of my TTs.
  • harley4275 wrote:
    When you turn the jack you do this by turning the head not the base. I have done this to a barker and an lci . Each worked great for tailgate clearance .
    Not necessarily ... the older UltraFab 3002 I owned a few years ago did allow rotating just the head, my current UltraFab 3502 does not. No doubt some other brands don't allow rotation of the head either, likewise there are some that have additional holes in the mounting plate that allow rotating of the entire jack. Unfortunately the OP hasn't told us just which tongue jack he has so whether the head could be rotated or not none of us can answer.
  • When you turn the jack you do this by turning the head not the base. I have done this to a barker and an lci . Each worked great for tailgate clearance .
  • rirish1 wrote:
    I'm only 2 inches high.
    That TT must seem really big to you. :B
  • I thought if I turned the power jack it would work. Unfortunately when I tried it the mounting bolts wouldn't line up. Mine is a triangle mounting plate not a circle.
    I thought that if I was replacing the shank I might as well go to 2.5 inch. Seems like I can't get what I want commercially. The equalizer 18 inch length doesn't have the drop that I need. I will look at the Curt 17122.
    How important is it to tow the TT level? I tend to be a perfectionist but the reality is I've been on several long trips and haven't had a problem. I'm only 2 inches high.
  • lawrosa wrote:
    https://www.etrailer.com/Accessories-and-Parts/Reese/RP54977.html
    You may be best off with a reducer to get you the length.. Then stay 2"..
    https://www.etrailer.com/Hitch-Adapters/Brophy/HR26.html?feed=npn&gclid=Cj0KCQiAh_DTBRCTARIsABlT9MavQ3qKBNx-Fz-SPcQDhq2zlsOBNJXWBc6vjzEZKsxrhR2SZ6xDj4MaAmQBEALw_wcB
    CAUTION!!! You CANNOT use a WD hitch with a reducer that also gives you length!!
    They are not nearly strong enough.
    The OP is on the right track.
    A longer drawbar with more drop is what he needs.
    I have an EQUALIZER 18" long one made of chromolly steel. It is a 2" but is rated the same as the 2.5" ones. I recommend staying with 2" and using the reducer. Since there is no strength advantage in the 2.5"one.
    If you go with the 2.5 and your TT ever needs to be towed by another "backup" TV in a pinch, the 2" one has a better chance of fitting in the receiver of the Backup.
  • I use an Equal-i-zer 4 point WD system on my rig. My tow vehicle is in my signature below. The tail gate also touches the electric tongue jack.
    Two ways to get around this. First is to turn the tongue jack 1/3 way around so the motor is out of the way of tail gate. I have not done this to my trailer yet (in 4 years), but I keep thinking someday I will. That's probably the easiest solution.
    The other way to open the tail gate and not hit the jack is to lower the jack to the ground and let it lift the truck up, like when you are attaching the weight distribution bars. This will cause the angle of the truck and trailer to allow the tail gate to open all the way without hitting the electric jack.
    Sometimes, if parked on just the right hill, or bump, or dip in the road or asphalt, the angle gets just right, the tail gate will open without hitting. But when it does, I just lower the jack and let it lift the truck end. This works pretty well, and I suppose I've gotten into this lazy mode, thus the reason I've not turned the jack yet and repositioned in the 3 holes on the A-frame.
    Their standard shank is 90-02-4100, which is a 2" shank, 12" long x 3" drop, 7" rise. It looks like it's 8" long from hole-to-hole.
    They have a 90-02-4900, which is 2-1/2" shank, 12" long x 6" drop, 10" rise. What you want, except for length.
    Curt makes a 17122, which is 2" shank, should have more than enough drop, and is 14" long hole-to-hole, so you'd pick up 6" in length. It's rated for 15K. What you want, except not 2 1/2.
