nohurry
Jun 12, 2016Explorer
scbwr wrote:
The nylon pads do help reduce noise. With proper lubrication and use of the pads, my Equalizer hitch is pretty quiet most of the time. But, I don't have the E2 model. However, the pads serve the same purpose on both hitches.
Ditto. But just to clarify, you don't lubricate the pads. You'll lose the sway control function.
I have the 4 way 12K equal-I-zer and love it. I use the Pads, and I use heavy grease (like wheel bearing grease), around the pivot points. i.e. Friction areas of the sockets where the bars slide in. Use an old tooth brush. I do this before I leave home, then again before I leave the campsite and it stays pretty quiet. The only time I hear it is when I turn sharply backing up sometimes.
