sbowman871's avatar
sbowman871
Erratic water flow
My kitchen and bathroom faucets are both flowing very erratic. Almost in a spray type pattern. I think I know what caused the condition. Early this year I did a quick winterization. Using compressed air through the city connection. After I de- winterized I noticed this abnormal water flow. Could it be debris just caught in the faucet or line? I have taken out the diffuser screens, no change there. Any ideas?
  • Pump seems to run consistent. I'm thinking there is some abstraction right at the faucet. Maybe I should try and snake a wire up in the faucet and see if that helps.
  • Do you hear your water pump kicking on and off? If so, perhaps the compressor caused some damage to the valves in the pump.
    Mike
  • If you are using a pressure regulator there may be something inside of it that is causing a problem.
  • RoyB's avatar
    RoyB
    Explorer II
    I use the air compressor method all the time here but the compressor is a tankless 12VDC model. It takes a longer time to build up pressure which is what I like to see when connected to the city water port.
    They warn you against hitting the water lines with alot of air pressure...
    Roy Ken
  • RoyB's avatar
    RoyB
    Explorer II
    My trailer has one of these in-line clear water canister filters just a few inches away from the city water connection.
    Might check to see if you have one. You can unscrew the canister with the city water disconnected and check the filter...
    Roy Ken
