NCMODELA's avatar
NCMODELA
Eternabond over butyl tape
Hi all, I am putting my trailer back together and was wondering if and how you guys remove the butyl tape and dicor sealant. The instructions with the eternabond said clean with a acetone solvent. However it doesn't take all of the butyl and dicor sealant off. But cleans up the paint really well :)
Do you guys just get the big stuff off and then lay it over that? or do you get it completely off.
Thanks
Bill
  • There is a current thread in the "tech issues" section, currently, on Eternabond and bond failures.
    You have detected the cause of many bond failures with the tape. The surface needs to be cleaned and sealant residue removed. Acetone won't remove some residues. I've had good luck with mineral spirits followed by lacquer thinner. You need to be careful of paint surfaces when using lacquer thinner. I think some folks have good luck applying the tape over prior sealants because they leave a cleaned surface outboard of the sealant joint and the tape is able to adhere to those surfaces.
    If it was me (and it was), I'd remove any prior sealants and all the residue before applying the tape.
  • I have used EternaBond over the years. It sticks to most anything except silicon caulk. Were it me, I would do as you have done by cleaning with acetone then tape over it. I like to use Eternabmd that will give me a two inch lap on both sides of the joint I'm tapeing. One inch absolute minimum.
