RollandB
Oct 02, 2021Explorer
X2 on removing the metal corner molding, first I’d check the water damage JD deal with repairing it as left alone will just get worse. Then put down new butyl tape, then reinstall the metal trim and seal with Dicor.
A good video to watch is this one….. https://youtu.be/PO8EvZ4AAp8
In it you will see a Dicor corner tape available on Amazon used. If I ever have to do this job it’s exactly what I would use….. https://www.amazon.com/Dicor-CS200B-1-Seal-Tite-Corner-Seal/dp/B0778W37ZD?dchild=1&keywords=Dicor+CS200B-1+Seal-Tite+Corner+Seal+Tape+-+2%22+x+50%27&qid=1626444496&sr=8-1&linkCode=sl1&tag=lo02f-20&linkId=1955b9423a92affab706dfd5d1c137b8&language=en_US&ref_=as_li_ss_tl
44,068 PostsLatest Activity: Jun 01, 2026
