nickthehunter wrote:
Lwiddis wrote:
Keep guessing! Refueling ICEs in the very early days was done by buying gasoline in one gallon containers from a hardware store. Lead, follow or get out of the way. California chooses to lead.
Leads to what?
Good example of how CA leads
Did you highlight the part in purple? The author is incorrect. Here's the original 2008 plan from then-Gov Schwarzenegger's(R) administration for the High-Speed Rail. Note that the author of the article you quote is off by a decade in the original estimated 90% completion mark. It was originally scheduled to open in 2030, not 2020 as the article says. Also, note that they left out the fact that all of the numbers quoted were in 2008 dollars and not adjusted for inflation. Just another misleading article.
https://hsr.ca.gov/wp-content/uploads/docs/about/business_plans/BPlan_2008_FullRpt.pdf
The HS rail has spanned several administrations from both parties
