My brother owns a 2015 GMC 2500HD, DuraMax/Allison 4X4 with a GVWR of 10,000lbs. It CAT scaled with him, his DW and a full tank at 8000lbs. This leaves him 2000lbs remaining payload. They are inte...
If he stays under his axle and tire ratings he'll be fine. The difference between his truck and a SRW 3500 is just a softer rear spring pack, or maybe a missing overload spring, or in some cases maybe nothing. His payload is low because 10,000 lbs is the max GVWR allowed for a class 2 truck, and his truck weighs a lot. It has nothing to do with capability. I would assume his rear axle rating is in the neighborhood of 6500 lbs, and his tires should be above that.
