2112
Apr 11, 2017Explorer II
Exceeding GVWR
My brother owns a 2015 GMC 2500HD, DuraMax/Allison 4X4 with a GVWR of 10,000lbs. It CAT scaled with him, his DW and a full tank at 8000lbs. This leaves him 2000lbs remaining payload. They are inte...
IdaD wrote:
If he stays under his axle and tire ratings he'll be fine. The difference between his truck and a SRW 3500 is just a softer rear spring pack, or maybe a missing overload spring, or in some cases maybe nothing. His payload is low because 10,000 lbs is the max GVWR allowed for a class 2 truck, and his truck weighs a lot. It has nothing to do with capability. I would assume his rear axle rating is in the neighborhood of 6500 lbs, and his tires should be above that.
