Blanco1's avatar
Blanco1
Exhaust Brake on a 12 valve Hot Rod Cummings, manual trans?
I’ve been considering an Exhaust Brake for years while traveling with our big Lance 900 in our truck bed.
But now that I have sold that & I’m towing a heavier Travel Trailer & on our 1st outing probably drove around 2000 miles & I’ve sold off my other toys & plan to focus on my tow rig & want to start with an exhaust brake & maybe water/meth injection after that?
I was telling a co worker & he started asking about being I have mods bringing me to 500 HP.
If that might be an issue?
I can’t imagine why it would cause problems?
But wonder if I’m wrong?
& then what might be my best bet for the best help on those long steep grades?
Don’t want to be over heating my brakes.
I figured I’d mount the switch right under the shifter knob.
I’ve heard there’s even adjustable models & some with built in safety’s like in case I forget to turn off the brake I don’t stall the truck while shifting?
I’ve heard of other options that would also turn it off when I accelerate.
& back when when I let off?
I’ve also heard of turbos that have them built in to it?
& would those work as well with out lowering my HP?
I also would mention , I have a 4” straight pipe from the turbo.
  • I may be wrong but I've never heard of an EB disconnecting when pushing the clutch. Mine is controlled by the trucks ECM and does not disengage with clutch pedal action - and I'm not sure why it would. There's no reason to have it disengage while your shifting either up or down.
    Normally for models earlier than the Common Rails, a switch is attached to the throttle pedal so anytime you have your foot on it, it disengages or engages anytime you take your foot off.
    Engine mods have no relation to the EB so your safe there. You do need to have the appropriate valve springs and I don't know if your truck came with them or not. (I think so). The switch under the shift lever works great and is where I put mine. It's very convenient and causes a lot of questions!
    I think you'll find you wish you would have put one on sooner and
    I can't imagine being without it!
    (BTW, it's a "Cummins")
  • All I could afford wrote:
    Generally the exhaust brake wiring would tie into the clutch pedal safety switch, similar to cruise control and that it would disconnect when you pressed on the clutch. Of course being you are adding the exhaust break after market you might need to be creative with the wiring to do such.
    Interesting, thanks.
  • Generally the exhaust brake wiring would tie into the clutch pedal safety switch, similar to cruise control and that it would disconnect when you pressed on the clutch. Of course being you are adding the exhaust break after market you might need to be creative with the wiring to do such.
