From what I can tell most pickups with diesel engines do not come with exhaust brakes on them, except, I believe, for the latest iteration of the 6.7 Cummins. For those of you who have diesels, do ...
I don't believe that changing pads is the issue. The issue is that you may have to use the brakes so much that they overheat to the point where they don't work AND you're only half way down that 6% grade. Then you get to try out one of those runaway ramps.
