carringb
Mar 30, 2020Explorer
hertfordnc wrote:
THanks. This truck will probably never do prolonged heavy towing. Occasional vehicle rescue, occasional transport of heavy load of building material but generally it will pull a small trailer or run empty.
I want to load 4X8 sheets and close the door, i want to fill the back with bricks and not flatten the springs.
If you want hauls those building products, a VAN will do it way better. You can load 2 pallets of bricks or pavers using a forklift (one into each door), where you'd be hand loading them into an SUV, and it'll swallow sheets of plywood onto its flat floor, with room to spare.
And FWIW - An E350 has over double the payload of an Excursion. But, it is harder to find the V10.
44,056 PostsLatest Activity: Mar 02, 2026
