colliehauler wrote:
akblackfoot wrote:
Passengers and fuel are about 650. So still under tow weight and GCVW even IF I load the trailer to the max. Hitch weight is listed at 740, so 120 less than max, leaving room for the WD hitchD weight. Has air bag leveling also. Still too much?
Do you travel with absolutely nothing in the trailer? Everything you add will add to the tongue weight. Listed weight is empty trailer. Air bags do nothing to increase your axle weight rating.
5700 is listed weight. 740 is tongue weight when loaded to the maximum gvw of 7600, correct? 7600-5700 is 1900 lbs of batteries, propane, water, and camping gear.
