PA12DRVR
Sep 30, 2019Explorer
Only did the RV thing for about 12 years:
- Had small (19' to large 33') travel trailers and large 39' - 16000 lbs 5th Wheel
- Used everything from a 2wd Yukon to a 2500 Suburban to a 2500 Silverado to an F350 on the travel trailers; F350 on the 5th wheel.
- Went mostly on the Gulf Coast with frequent trips to CO (1-2 times per year) and the Carolinas (2-3 times per year)
- Had both 2wd and 4wd (in different vehicles) towing the travel trailers. Had both a 2wd and 4wd F350 thanks to an acquisitive car thief.
- Much prefer going bigger for towing. Within reasonable limits, of course the 2500 will do it; more comfortable to use a 3500 vehicle.
- Got stuck 3 times with 2wd: all on wet grass involving uphill and a heavy (for the vehicle) trailer. Never got stuck (even though driving twice through the same spot years later) with 4wd.
- I live in Alaska...so will never own anything less than an AWD vehicle again but for the OP's use, I'd suggest (if it's an option) using the $$ on going 3500 vs. 2500 and not doing 4wd.
