LIKE2BUILD
Oct 07, 2019Explorer
Nighduckman wrote:
.....I understand we will likely get stuck once in a while, but, will have a tow strap and I understand we can usually count on a nice 4x4 owner to tow us out and/or we have GoodSam towing assistance. Again, we are not going to off road or seriously boondock. We won't be driving the rig in snow etc.
The 2WD will tow your camper perfectly fine and if you stay on 'improved' roads you will most likely not need 4WD at all.
I towed with a Chevy 2500HD 2WD for 10 years. That truck did everything I ever needed it to do, except for a few occasions. It came factory with an open differential and I eventually installed an Eaton LSD. The limited slip did make a difference but after having been stuck on wet grass, wet boat ramps, and snow I'd had enough. The last gotcha was towing my camper to a NASCAR race and the campground had gravel roads and grass sites. While parking the camper I spun the rear tires and was stuck dead to rites. Of course the front wheels were on solid gravel and could have pulled me up....IF I WOULD HAVE HAD 4X4 :M That was my final straw and within 2 weeks I had a my Ram 4WD in the driveway.
Your situation sounds a little different and you will most likely not need 4WD. In my case I had just enough situations of getting stuck that I was no longer willing to deal with it.
KJ
