You'd be better off with a Tahoe than a suburban unless you go with the suburban 2500. With your weight trailer, the Tahoe should do everything you need. Suburbans were meant to be people haulers. They have less towing capacity than a Tahoe by a couple hundred pounds. The Expedition has one of the highest tow rating amongst the standard SUVs at around, but I prefer Chevy to Ford.
I've had the SUV debate with myself over and over. My only choice to move up would be the Suburban 2500, but they are def a rare breed and you prob wouldn't want that as your daily driver for work. If I were you I'd go with a Tahoe, but even a 2010 Tahoe will run you mid to high $20s unless it has crazy high mileage.
